Help with the Meguiar's Dual Action Power System
  • #16
    Re: Help with the Meguiar's Dual Action Power System
    Very good information.
    At the moment I have paint in good condition (for daily driver,white colored car, and I don't think I need to use compound). I use cleaner wax to clean and after I go with ULW (by hand and using foam applicator pads). Now I purchase DA power system to be a little faster and I'm interested if I can use cleaner wax with yellow polishing pad? (or is this bad idea and not recommend, should go and use UP to still have a little cleaning before wax?)
    • #17
      The Cleaner/Wax or the Ult. Polish could be used on the yellow pad. Whichever you prefer.
      • #18
        Did I understand correctly ''Pad Packs'' or the W7204 (for compounding), W8204 (for compounding/polishing ) and W9204 can be used for wax application?
        • #19
          Yes, those are correct numbers for the 4 inch pads, but I dont think they will have the DA System packaging. (not that it matters)... Those packs have 2 pads.
          The Power System Packaging would be G3507, G3508, G3509 if you cared, for the 2-pad packs.
          • #20
            Btw... those power system pads works pretty well with a 3" LC BP on a DA.
            2012 Acura CBP TL SH-AWD Tech
            • #21
              I was thinking to use those packs with DA Power system and im not sure are this the same as power pack (for example w9204 for wax aplication)?
              • #22
                DA power system power packs are the exact same pads as the 4" Softbuff 2.0 pads.
