First question is aircraft paint. Polytone paint is a solvent based paint. it has finally oxidized enough that wet water rag will show paint after wiping in the worst areas (top of Wings). it cuts easily with lacquer thinner or MEK. It does seem to shime up for a bit with pledge or some waxes...
What is suggested to cut the oxidation and put moisture into paint? then what type of sealer or wax
Second is there a product flow chart that you can look up your description of paint condition and have a prescription of product to use?
Thank You
Eric
Thank You
Eric
