Should I change up my routine?
  • Should I change up my routine?
    I'm considering replacing #7 with M03 machine glaze. How do they compare?
    This is my regular routine on my personal vehicles:
    1. Wash (Gold class)
    2. Clay
    3. M105 with orange pad (I usually only do this on neglected finishes)
    4. M205 with orange pad
    5. #7 show car glaze black pad
    6. NXT 2.0 black pad 2 coats
    3-6 are all porter cable DA applied, MF removed.
    What I've noticed is the #7 doesn't seem to play well with the NXT. I've read up on the #7 and there are 2 camps: Those that don't allow it to dry before removing, and those that will cover the whole car before removing. I have tried both methods with varying degrees of success. Black honda civic, Gray GMC pickup, and a Silver Infiniti fx35.
    The #7 is relatively cumbersome to work with IMO, but if done correctly look amazing. Such was the case with the black Honda:
    It seemed like the #7 wanted to smear the entire time. I had better luck with letting it dry on this car, but was still very burdensome to get off. I did manage to get great results and the NXT only sealed the deal.
    I noticed on the GMC, however, that I had a few areas that seemed hazy after using the NXT behind the #7. I have let the glaze dry as I had with the Civic once, and I have buffed it a panel at a time once as well and both times, I don't notice the haze until after wiping away the first coat of NXT. I was very conscious of how much NXT I was applying... it was so thin that I could barely tell any was there. I was able to buff these areas out before applying the second coat of NXT.
    The real problem was when I went after the Infiniti... I didn't get any pictures of the haze, but this is the color I'm dealing with:
    It was splotchy. It had this hazy darker hue in places. I mean it was so bad that I couldn't get it to buff out, even before applying the NXT. I ended up going back over the entire thing with the 205, skipping the #7, and topping with the NXT.
    So....
    I'm thinking that I am going to abandon the #7 all together; however, I feel that I want something in it's place since it does provide a deeper luster than going from the 205 straight to the NXT, and would like your opinion on the M03 machine glaze.
    Also how does the M21 compare to the NXT??
    I am contemplating changing to:
    2. Clay
    5. M03 Machine glaze black pad
    6. M21 Synthetic Sealant 2.0 black pad 2 coats
    With the D156 Synthetic X-press Spray wax in the interim to keep up appearance (which I do not do now).
    What do you guys think?
    Re: Should I change up my routine?
    I would just remove step 5 altogether and use M205 with a black finishing pad. M205 is heavy with polishing oils and it's an AWESOME finishing polish. So you can just jump straight to LSP after.
    AFAIK, M21 and NXT are very similar products, if not the same. M21 is the mirror glaze label of NXT. M21 can also be applied by rotary.
    D156 or Ultimate Quik Wax is a great way to boost your car's looks and protection after every wash.
      Agreed.
      M205 used with a slower speed, slower arm movements and a black finishing pad really bring out the gloss. It's also a product you already have, so saves you a few pennies too!
        Agreed here too. Skip Step 5 altogether. It's not required.
        M205 gives amazing gloss and clarity on its own and I can't see how you could further improve the appearance (noticably) with M07.
        As for letting M07 dry... ... no wonder you were having troubles removing it! You should remove it while still wet.
          M07 can be troublesome, but it does add that extra wetness and richness. It does get a bit of getting used to, you have to remove it while wet and it is recommended that you have extra microfiber towels when removing M07.
