I'm picking up a 2000 Mercedes E320. I would rather not like to paint the hood, improve the look or polish it out to would be my preferred thing to do. The hood looks just like this picture, just very hazy. Is it able to be revived at all or do I just need to start off fresh?
Clear coat issue on 2000 Mercedes, able to be saved?
Re: Clear coat issue on 2000 Mercedes, able to be saved?
Sorry no saving CC failure.
You have to repaint.
You can sand off the CC and polish the base coat.
this is not recommended as the Base coat is very thin and needs the CC to protect it.
The base coat is just there for color then the CC protects it
That sure does look like pretty advanced clear coat failure, the only cure for which is to strip and repaint. You might see a pretty sizeable improvement immediately after compounding with something like Ultimate Compound, but once the clear is failing any such improvement will be very short lived. It could be as little as a few days before it starts to look like this again, or it could take a couple of weeks, but it's not going to be a permanent fix by any stretch of the imagination.
Originally posted by Please Wash Me Detailing View PostYou can sand off the CC and polish the base coat.
Unfortunately, the only real fix is to strip it down and fully repaint it.Michael Stoops
I did this search because I have the same problem with the hopes of restoring the CC to some degree to get a little more life while i save up for a decent spray job. I guess this much oxidation has to be repaired at the paint shop. One question I have is, what does "strip" mean. Are you guys talking about going down to bare metal or sanding the base coat to create a paintable surface?
