Stubborn water spots...help!
  • Stubborn water spots...help!
    My hood is covered in nasty water spots from when it rained last week. After I washed my car (a week after it rained) the water spots are still there. I went over the hood with M105 and M205 (twice) using a orbital buffer but they are still there! What should I try next? THANX!
    They look like possible acid rain damage do you live in an area where thats common? Also what polisher/pads and speed were you running
    Even the best cars look like junk when they are not clean
      Re: Stubborn water spots...help!
      When you say "orbital buffer", do you mean something like this?
      They generally don't have enough power to remove defects, as explained here:
      Lately i have seen a lot of threads regarding pc vs a regular orbital buffer. I was wondering what are the difference between these 3 options. What are the pros and cons of these three tools. Thanks... -Mike
        Its not acid rain I live in San Diego CA. I'm thinking water from the road beaded and settled on my hood. And when the water dried whatever was mixed with it etched into the clear coat. I used a basic Sears Craftsman orbital buffer. I used a basic wool pad with the M105 and a basic terry cloth pad with the M205. There is only one speed.
          http://www.meguiarsonline.com/forums...ital-Buffer&s=
          Thanx for posting the link. Do you think the Meguiar's G3500 DA PowerSystem Tool
          + M105 should have enough power to do the trick?
            Hard to say (gut feel is that it will), but it would be more powerful than the buffer you are currently using for sure.
              Well.. I went over half the hood using the G3500 DA power system tool and M105. It made a big improvement but the water spots are still visible. Any more suggestions? THANX!
                How fast were you moving the tool across the paint? How big an area were you working on at once? How much downward pressure?
                  I followed this video:
                    Unfortunately that vid does not illustrate how how slow you have to sometimes go to remove defects.
                    You need to slow your arm speed right down and concentrate on about a 12" x 12" area at a time.
                      Thanx for your help. Once I realized my cordless drill only spins at 850 rpm, I got a corded drill (2500 rpm) and it made all the difference in the world! I got it all out and my hood look looks great know!
