Help! I got a brand new VW over the weekend. Unfortunately, someone must have used something abrasive or a dirty rag on the outside and the windshield has a number of faint but noticeable scratches over one half of it. I can't feel the scratches with my fingernails, but I can see them. So far I tried Cleaner Wax and ScratchX 2.0 by hand with no improvement. I know and understand that glass is much harder than paint, but this VW windshield must be real soft because it is obvious that the scratches were made by hand, not by machine or the windshield wipers. So I am trying to use the least aggressive methods first. Since ScratchX 2.0 did nothing, would it be worth it to try Ultimate Compound or is that almost the same and a waste of money? Should I try one of the headlight polishing kits instead? thanks.
Help-New Car-Windshield scratches
Re: Help-New Car-Windshield scratches
I have a bottle of CarPro Ceriglass cleaner, I don't have scratches on my windows, but depending on the severity of your scratches, this may work for you?
"STRIFE" aka Phil
Welcome to MOL!
Scratches in glass can be extremely difficult to polish out simply because glass is so much harder than paint, as you've already pointed out. Even though these scratches may have been inflicted by hand, that doesn't necessarily mean the glass is "soft" - the mechanism involved in creating a scratch is vastly different than the process used to remove that scratch, regardless of the material that has been scratched. The scratch is caused by something hard with a very small surface area being dragged across the surface, whether that's the cotton loops of an old terry towel being dragged over paint, a small piece of debris being caught in an otherwise safe towel and then dragged over the paint, or a similarly hard but very small object being dragged over the glass. It's harder to cause a scratch in glass this way, but it can certainly be done. The problem is the polishing process, which is essentially a leveling of the surface through an abrasive process rather than simply cutting into the surface. Think about creating a scratch in a stick of warm butter - take a sharp knife and gently drag it over the top of the butter stick and you'll easily cut into it, basically causing a scratch. Now do the same thing with a very sharp knife and a very tender steak. It's still pretty easy to make a shallow cut, or scratch, in the piece of meat. Now try to make that stick of butter flat and level again on top. Pretty easy just by gently dragging a flat blade over it, leveling the surface flat again. Try that with the steak and you're going to really struggle with the process!
Fine scratches in glass aren't going to go away with ScratchX 2.0 or Ultimate Compound (at least we'd be pretty shocked if they did and were in fact actual scratches in the glass) - they just aren't designed to do this. Unfortunately, we don't make anything specifically for polishing glass. There are glass polishing kits on the market, however, and almost all of them use cerium oxide as the abrasive component because it's one of the few things that can effectively polish glass. Even so, doing it by hand still be quite a challenge. You might want to do some Google searching for glass polishing kit and read some product reviews before choosing one.Michael Stoops
I've Polish glass with Cerium Oxide here's a random link on it http://www.gtglass.com/glass-scratch...FayPPAodPA8A1Q
and you can get polishing pads from Auto Detailing Solutions and then have other glass stuff too.
And don't use any headlight restoration system, that's for plastic, glass is a whole other animal.
So you should be able to polish out light scratches, I have before
do a search here and you'll find more posts on polishing glass
here's a random one
Search the forums and you will find thousands of threads about the correction of defects from paint - hard paint, soft paint, white paint, black paint, pink paint etc etc etc... But you'll also notice a complete dearth of threads about removing defects from glass! In this thread I am going to introduce a technique and polishes
I was working with the dealer since I found the issue, 2 days after I bought the car. They had a glass company come by and try to polish the glass, but they decided to just go ahead and replace the windshield. Not all that happy about getting the windshield replaced in a brand new car, but it is what it is. I'll inspect the glass much better the next car I buy... :-)
Originally posted by Gtechy View PostI was working with the dealer since I found the issue, 2 days after I bought the car. They had a glass company come by and try to polish the glass, but they decided to just go ahead and replace the windshield. Not all that happy about getting the windshield replaced in a brand new car, but it is what it is. I'll inspect the glass much better the next car I buy... :-)
Yes, it is VW OEM glass, the glass company did a very good job on it. They had the car sit for 4 hours before allowing it to move, which tells me that they problably used the right adhesives vs. the 1 hr quick ones. All in all, the new glass makes a big difference at night. What happened to the original one and how it got so scratched up, I'll never know. I was so focused on checking the paint and since I've never had a problem with a new car glass didn't give it a thought. Word to the wise, check the glass on any new car. 45 years old and still learning life leassons...
