My real question is, say I use the Ultimate combo, UC, UP, UPW. Can you top UPW right after UP? Has it been proven that a sealant needs a perfectly clean surface to bond properly, like using IPA? Thanks.
a IPA wipe down really needed after using a polish?
Re: a IPA wipe down really needed after using a polish?
Originally posted by Jomax View PostMy real question is, say I use the Ultimate combo, UC, UP, UPW. Can you top UPW right after UP? Has it been proven that a sealant needs a perfectly clean surface to bond properly, like using IPA? Thanks.
Meguairs only recomends the IPA wipe to check your work if needed. They like to have polish on the surface.
A couple companies say to have a surface with no oils, so you should follow their recomendations.2017 Subaru WRX Premium - WR Blue
If you're going from a Megs polish/compound to a Megs wax, then there is no IPA wipedown required.
If you want to make 100% sure you've removed all defects instead of hiding them, then knock yourself out!Originally posted by BluelineI own a silver vehicle and a black vehicle owns me. The black one demands attention, washing, detailing, waxing and an occasional dinner out at a nice restaurant. The silver one demands nothing and it looks just fine. I think the black vehicle is taking advantage of me, and the silver car is more my style. We can go out for a drive without her makeup and she looks fine. If I want to take the black one out, it is three or four hours in the "bathroom" to get ready.
Isopropyl alcohol - IPA used to remove traces of wax or compounds or polishes hiding in swirls. If swirls can't be seen they can't be removed and may show up again when you don't want them to, which is most of the time.
(Oh and not a stupid question!)
David
It should be noted that isopropyl alcohol should not be used straight but rather diluted with water so that you have a roughly 15% - 25% concentration. That should be more than sufficient to remove any oils, solvents, etc from the compounds and polishes you're using. But as has been noted, if you're using all Meguiar's products then there is no need for an IPA wipedown prior to applying any of our waxes/sealants.Michael Stoops
I just rec'd a bottle of Car Pro Eraser
CARPRO Eraser Intense Oil & Polish Cleanser - Put your best finish forward with Eraser! CARPRO Eraser is an IPA and more! Eraser is an intense cleaner designed to dissolve oil particles and remove polish residue to prepare the paintwork for ...
As mentioned with Megs waxes/sealants not needing a IPA wipedown, still a good step to use if you have time?"STRIFE" aka Phil
As mentioned with Megs waxes/sealants not needing a IPA wipedown, still a good step to use if you have time?Michael Stoops
^ thanks Michael for the clarification"STRIFE" aka Phil
