Differences between bottles Ultimate Compound
  • Differences between bottles Ultimate Compound
    Is there a differences between this
    to this >
    Re: Differences between bottles Ultimate Compound
    Dont know of any UC changes that have been made.
      I have one of each....think the only difference is the cap/dispensor and the graphics....formulation still the same I assume?
      "STRIFE" aka Phil
        on one writes "clear coat safe" and on the other... nothing
          Everything Meguiars makes is clear coat safe, so no problems there. (when used properly of course)
            I'm pretty sure it's still clear coat safe, maybe Megs just wants a "cleaner" looking bottle......perhaps Mr Stoops can confirm
            "STRIFE" aka Phil
              The updated graphic/stickers on the bottles to match the rest of the other products in the ultimate line and different top is all, the formulation is still the same i bet.
                i wait for mr stoops to be sure
                  I can understand that you are new, but it's ok to trust other people on here. We're all here to help so Mike doesn't have to answer every question lol.
                  Murr1525 has 17,000 post and been here for 8yrs!!!! I think he's pretty reliable? I can assure you, Meguiar's would not add a non clear coat safe product to their consumer line. Refer to post link below about label change.
                    It's the same, only the graphics and bottle dispenser was changed. If the product works well and this one certainly does, there's no reason to change the formulation. I had an old bottle which was still 1/3 full, planned on buying another one but being a compound, I realized I wouldn't be able to use it regularly so just got myself the "Junior Sized" bottle, tried it on a small area, application and results were the same. So I just poured it into the 1/3 full bottle and shook it up to mix them up real good.
                    Clear coat safe? Sure, using the right technique it will yield great results thanks to the SMAT's found in this. Poor technique though, and it will yield horrible results.
