Con any one tell what is the diffrence between Mirror glaze sealant and the ultimate wax. Is the Mirror glaze sealane can be applied by DA or just hand application and what pad and speed you recommend. Next, can be topped by yellow paste wax#26.
Mirroe Glaze Syhtentic Sealant 2.0
Re: Mirroe Glaze Syhtentic Sealant 2.0
M21 Synthetic Sealant is the professional version of NxT Tech Wax 2.0 . It's a synthetic wax offering long protection time. M21 can be also applied by rotary buffer (NxT 2.0 cannnot).
Ultimate Wax is Meguiar's newest synthetic wax/ sealant and it's durability has been further improved. It works great on dark colored metallic paints.
All Meguiar's waxes/ sealants can be applied by hand, orbital buffers and random orbital polishers (dual action/ D/A polishers), M21 and M26 can be also applied by rotary buffers. Finishing pad (speed 2-3 D/A polisher or 600-1200 rpm rotary buffer) would be the proper way of application.
M26 High Tech Yellow Wax contains mix of natural and synthetic ingredients (it's often called a hybrid wax). It's quite common to top synthetic wax/ sealant with natural/ carnauba based wax, just remember about 24-hour cure time for most synthetic waxes before topping.
There is a minor tweak to the formulation of M21 vs NXT that allows it to better withstand the shear forces and heat created by a rotary buffer. Even so, it's not terribly common to see anyone apply a wax or sealant with a rotary these days. Both can be applied by hand or with a DA.Michael Stoops
When Meguiar's has the 'body shop safe' statement, they are referring to the fact that there are no ingredients that will affect painting. Generally that means no silicone. Silicone and paint spraying don't play well together at all.
Bill
Can I use it with no issue - please advice. Next if this is the professional version of NxT Tech Wax 2.0 why we have this statement? I just I need to understand how this products can work together. My plan is that:
1- use Swirls X or ultimate polish to clean the surface ( the paint is in very good condition - BMW 2008 black)
2- apply glaze sealant 2.0
3- apply yellow wax for more depth
