I own a 1968 Camaro convertible that I have had for about 8 years. The car was repainted roughly 10-12 years ago. It is a show car/cruise night vehicle and the only thing I have ever done to the finish is Meg's #7 and Meg's #26 or NXT. This year, I wanted to set out to remove some of the swirls that have accumulated over the years. So last night, I figured I would start with Meg's Scratch - X (by hand) to remove a few of the more noticeable scuffs and slight scratches, then move on to the PC. Well to my surprise, the applicator pad turned reddish/pink after applying the Scratch-X. So, it appears I have single stage paint. I would have bet 100% otherwise but that looks like it's the case.
My question is, because it is single stage, do I need to take any additional "precautions" when working with single stage or change the process I had decided on. I do have a PC and wanted to go with: Megs #80 with a Meg's polishing pad, Followed by #81 with a polishing pad, followed by NXT by hand then #26 by hand. That was my proposed plan - when I thought I had base coat/clear coat - but now I'm not so sure. Do you think that is still a good process given the s/stage paint on my car??
I'm hoping I don't have to go any more aggressive than the #80 but if I do, would stepping up to Meg's #83 (DACP) with a Megs' polishing pad still be acceptable on single stage - or - would the next step up be #80 with say a slightly more aggresive pad (not the Meg's cutting pad) Either way, I would follow that step with #80 again with a Meg's polishing pad.
And finally, is there a greater risk of damage to the paint using a PC because it is s/stage rather than base coat/clear coat?
Thanks very much!!
Thanks very much!!
