Removing water repellent
  • Removing water repellent
    Dear all,
    I think it is enough for me to deal with water repellent.
    my wiper only lasting for 2 weeks, and it will skipped, make a noise, and sometimes stuck when I using it. I replace it with the new one, different brand, and after two weeks, it will show the same symptom.
    Ok, I just want to know, ho to remove water repellent? I use clay, IPA, UC+DA, and none of them can permanently remove the water repellent.
    Is there something I do wrong? Can you share? Nothing is wrong with my body panel, but not with my windshiled.
    Really appreciate your sharing.
    Thank you
    Re: Removing water repellent
    What type / brand of water repellant is it?
    I would have thought that the things you've already tried should have removed it.
      I used to have rain-x and meg's glass cleaner. I applied it not at the same time.
      The other vehicle I use not show the same symptom, it just working well, and the only different is, I never put water repellent on the other.
      I use clay and UC to clean water spot on both windshield.
