My carbon fiber hood has had a cloudy appearance for a while so I searched the internet looking for a way to fix it. I was impressed with the results I found on Meguiars, I decided to try using the steps I saw on another thread http://www.meguiarsonline.com/forums...!-October-21st!
I followed these steps in general except I used a porter cable 7346sp with the included foam pad. I also waxed by hand.
My first time using the polisher didn't do much, I decided I wasn't really using any pressure and maybe I wasn't going slow enough. I went over it again using much more pressure and moving the polisher very slowly. I'm not sure I was successful in removing any of the oxidation, and there are now streaks and a sprinkled look over the vehicle, which on closer inspection I believe are tiny scratches in the clearcoat.
Any ideas on what I might be doing wrong?
- Wipe down with Quick Detailer to remove loose dust
- Clay with our Smooth Surface Clay Kit to remove above surface bonded contaminants
- Clean using M80 Speed Glaze with a W-8006 foam polishing pad on the G100 using the 5.0 setting.
- Protect using NXT Tech Wax with a W-9006 finishing pad on the 3.0 setting.
- Remove dried wax using our microfiber bonnet over a clean, dry W-7006 foam cutting pad on the 5.0 setting.
