Cleaning wool pads with zip tie? Any DIY cleaning tools or ideas
  • Cleaning wool pads with zip tie? Any DIY cleaning tools or ideas
    I saw a video where a 3M guy used a zip tie, patrially zipped to form a tear shape. Was closed up with some electrical tape. He didn't show how he did it, but I think he ran it accross a slow moving gunked up wool pad to strip the compound out of it.
    I also read somewhere where a guy used some curved needle nose pliers to do the same thing.
    Any other DIY ideas to unload a wool pad?
    Re: Cleaning wool pads with zip tie? Any DIY cleaning tools or ideas
    Got a link to that vid? Sounds interesting..
      Compressed air is my favorite pad cleaning method, although I've never tried it on wool. Maybe a pad spur?
        We've seen guys use screwdrivers, open end wrenches and even a fork to clean wool pads. But a good pad spur is under $10, is generally far more ergonomic to use, and won't rip up the pad like some of the above can.
        Of course, you could spend $125 or more on a proper pad washer, which might actually be a bit crazy for the casual user or weekend warrior, but for anyone who details a lot of cars these are great to have on site. If you ever encounter a car that just doesn't want to cooperate and you're forced to test several products and start running low on pads, you'll be glad you have one of these. But if you're just taking care of your own cars at home, it becomes a fairly major luxury item and not a real necessity.
          How do these pad washers work? Is there like a wash solution in the bucket?
          Saw a vid...where the user just placed the pad, still attached to the DA and closed the adjustable lid top, ran the DA, and the pad appeared clean again.
          Steep price but appears to be worth it
          "STRIFE" aka Phil
            Just found some info on auto geek regarding the pad washer....so the wash solution can be used for upto a week....but then don't you have to rinse out the wash solution?
            Btw...sorry to jack the thread! I wouldn't use anything else to clean my pads other than a proper DA pad cleaning brush
            "STRIFE" aka Phil
