Help fix what a "professional" couldnt and made worse
    Re: Help fix what a "professional" couldnt and made worse
    I think you need a DA!
    Im ordering one soon.I was referring to the result so far by hand, and my first time using UC.
      There could be a couple of things at play here that are conspiring against you: some Audi paint is quite hard, and some rotary swirls can be surprisingly deep. Put the two together and you've got a challenging situation, especially by hand. Even with hard paint, you still need to avoid those fingertip pressure points we discussed earlier in the thread, but if you're backing off too much you further reduce the ability to remove the rotary trails. It can be a bit of a double edged sword. Once you attack this with a good DA buffer, things should turn around dramatically for you.
