Is this Right?
  • Is this Right?
    Hey Shiny Heads,
    Want to know what I am doing is right or wrong, please advise.
    Clean the vehicle > Swirl-X the Vehicle with DA > Ultimate Compound with DA > Nxt Tech 2.0 or Gold Class With DA
    Clean the Vehicle > Diamond Cut with DA > Nxt tech 2.0 with DA or Gold Class 2 quotes with DA.
    If any one has tried this technique before please share your experience which will be worth of knowledge to me understand if any additional step required do let me know would love to follow up.
    Cheers,
    <Maddy>
    Re: Is this Right?
    By "clean" I assume you mean "wash"?
    You would want to use the UC before SwirlX..
      Re: Is this Right?
      Why is it that UC first and then followed by UC? Is there any strong reason why it should be this way?
      Appreciate if any one also can reply for this.
      Cheers,
      <Maddy>
        Re: Is this Right?
        The UC is the stronger product, and SwirlX is milder. So you would want to use the strong product first, and then use the milder one to clean up any left over marring.
        Kind of like working from coarse to fine sand paper.
          Re: Is this Right?
            Re: Is this Right?
            Thanks for the info provided friends, this will surely change the way the work i was doing or going to do. Once again thank you.
            Cheers,
            <Maddy>
