M40 vinyl cleaner conditioner 2 ?
  • M40 vinyl cleaner conditioner 2 ?
    Got some m40 for vinyl tonnuna cover. What best way to apply? Rag or brush?
    What other uses can this be use on?
    2000 Dodge Dakota 4.7 automatic 4x4 3 inch body lift
    Flowmaster 40 series duals 31x10.50x15 BFG 's
    Re: M40 vinyl cleaner conditioner 2 ?
    Nothing really best. On a cloth is usually easiest. I like to apply a dressing, wait a bit, then remove excess with a dry cloth.
    Could be used on tires, wheelwells, dash, bed liner.... among other plastic things.
      M40 is a great product.
      I'd start with a terry cloth. However, if the cover is really neglected you could try a brush application. Wipe off any excess product when you're finished for a uniform job.
        FYI Megs vinyl 40 is a water based product and will wash off in the rain. It is a great product for interior and engines, but will not stand up on a DD. You would want something like Megs ASD or the new Tire and Trim Gel, products more geared towards exterior use.
          I use M40 on wiper cowls and mesh style front grills. Use various size foam brushes, especially like the cylinder shaped ones on the end of a stick for both working around wipers and getting into mesh grills. Foam holds product without dripping all over.
          David
