What can I do to make this shine (pics)
  • What can I do to make this shine (pics)
    Album
    As you can see (hopefully), is that the car has oxidized paint. I am pretty sure it is a single stage paint...metallic grey. The last picture shows the biggest, deepest scratch - the rest is just fine scratches. What would be best for the long scratch?
    Unless there's someone out there in the Dallas area that wants to be generous and help, I must do it all by hand. Here's what I plan so far, please give advise.
    1. Wash car
    2. Claybar
    3. Ultimate Compound (?)
    4. ?
    5. Cleaner wax (#12)
    Also, what appropriate applicators should I use?
    Re: What can I do to make this shine (pics)
    I would try Ultimate Polish for step 4...Foam Applicator's...
      Hmm.. hard to tell if clear coated or not from the paint. What car is it/year? Just have to start working on it and see.
      1. Wash
      2. Clay
      3. Ult. Compound
      4. Ult. Polish
      5. Wax - Ult. Wax, Gold Class, etc, whichever you prefer.
      6. Wax - 2 thin coats are best
      I think that would give you a good shot by hand. Will be a good bit of work though, so dont focus on all in one day.
      Could also look at something like the CarPro TRIX before claying.
      I like the smooth foam applicators, like the yellow round ones.
      As far as the long scratch, probably wont be removable, though a little more of the UC over it can probably improve it.
        That's going to be hard work by hand.
        ...And by the looks of it, you may not get that last scratch out, though you should improve it.
          What applicator is recommended for Ultimate compound? (I only have the car wash soap and the CB kit at the moment)
            That's what I thought. Unsure as to whether I should get some paint matched and attempt to do something to it...
              Also if you add Show Car Glaze M07 to the process you will be set. And the pads you would use for each product would be the yellow foam pads
                This stuff sure does add up fast...
                Alright. Tomorrow I'll be starting with the wash and clay bar and then ultimate compound if I still have time.
                  Well, we can try to work around any options you needed. Or what to buy to try first, rather than all at once.
                  The further gone the paint is, the more effort/product it can be to restore.
                    Yea it can add up quick. For sure I would say
                    1) wash
                    2) clay
                    3) Ult. Compound
                    4) wax
                    If you want to take the extra step you could add Ult. Polish before waxing. To take it another step; along with Ult. Polish you could add Show Car Glaze M07.
                    Let us know how it goes.
                      I know, I know...
                      So what are the main ones I need to get for now?
                      - Wash
                      -Clay Bar
                      -Ultimate Compound
                      Oh yeah, the car is a 1990 Mercedes. I do recall hearing that metallic colors had clear...hmm..
                        As a minimum, buy a wax / sealant in addition to your list above.
                        If you're on a budget, perhaps look at getting NXT 2.0. Not quite as durable as UW but still a fantastic wax nonetheless and arguably easier to use..
                          Wash, clay, UC, Wax would be a good start, and then applicators, towels.
                          You might check around for the Paint Restoration Kit, though you already bought a couple things.
                            I've only bought the clay bar kit.
                            So the wax would be NXT 2.0 or UW? Would the cleaner wax be pretty pointless compared to those two?
                              You can go with either wax... UW would be the most durable. Nxt 2.0 applies more like old fashioned waxes, if you were used to them at all.
                              Yeah, the Cleaner/Wax would not be needed right now. You are already using a cleaner first, then a seperate wax after. Can help speed things up in the future though when you want a quick detail and the paint is in good shape.
