Some Question D300 Vs M105
  • Some Question D300 Vs M105
    Hi guys, I have some question, please help
    Which product is the most aggressive to Least aggressive ?
    1. D300 + Meg MF pad 6"
    2. M105 + Lake Country yellow pad
    3. M105 + Lake Country Orang pad
    and how many car you can detail with 32 oz D300 on average size car ?
    Thanks for helping
    Proud to be part of Meguiars Family
    Re: Some Question D300 Vs M105
    We would put those combos in the following order, from most to least aggressive:
    D300 + MF cutting pad
    M105 + LC yellow
    M105 + LC orange
    You mentioned the 6" MF disc, is that because you're using a Flex 3401? If not, you really should be using the 5" MF discs on a DA buffer.
    As for the number of cars you can correct with 32 oz of anything, that's always going to depend on how bad the defects are and therefore how many passes you need to make to fully correct the finish. You're always going to use more of a cutting compound than a finishing polish or wax so obviously we can't compare those types of products. But you'll probably use between 4 and 8 ounces of compound to do a full sized car, depending on severity of defects and your usage of product.
      M105 + LC yellow
      M105 + LC orange
      Thanks for answer Mr.Stoops
      No, in fact I'm using Meguiars 220V2 DA Polisher, sadly, Meguiars in my country didn't import 5" pad, but only 6" , but i'm still trying to make them change their mind , since very very few people in my country using Flex force rotation...
      Btw, i can use lake country backing plate with this DA MF pad right ? since the pad using micro hook...
