Wich one of this is better?
  • Wich one of this is better?
    im about to buy a DA kit from meguiars, i found 2 products that i can buy
    this one
    and this one
    i already have 7" pad 7k,8k,9k.
    what is the best to buy?
    Thank you.
    Re: Wich one of this is better?
    Not a huge fan of either...
    Where are you living at? Maybe we can look at other kits, depending on where you live.
      Im From Mexico, here this stuff is pretty expensive, a friend is coming from the USA next week, he is getting one of this for me, but i first need to decide wich one.
      He is in L.A. right now.
        Hey thepanchmx,
        Tell ur friend to get you the products you want off-shelf. That combo is way to expensive.
        Just get the polisher. You already have 7" pads.
        What are you aiming for ? what do you want to do? Do u want to work on your car? Are u a professional? Then the products you need comes from answering those questions
        Anything u need just let me know.
        Ryan's Auto Detailing, S.A
        Dominican Republic.
          Have you seen some of these kits?
            I second what murr says. Check this one out, just upgrade form the 12Oz. to the 32 Oz. and ur good to go
            Remember u already have Pads, the other things are easy to get towels, etc..
            Dominican Republic.
              im just a fan
              I dont do it in professional way im just a car detailing fan, i detail aome friends cars and stuff buf im not a pro, but i wanna make the cars looks like if i am.
              Also im wondering if this da helps me to sand? Thabk you
                The kits linked to by the OP are obviously not put together by us (there are competitors products in the mix) and quite frankly, we don't understand the kit with the cutting pads and finishing pads at all. We do not recommend using those pads with the DA because of how aggressive they are. If you want to stick with Amazon as a source, we'd suggest you just get the G110v2, a pair of W8207 yellow polishing pads, a pair of W9207 black finishing pads, some Ultimate Compound, Ultimate Polish and Ultimate Wax plus a bunch of microfiber towels. You'll spend the same amount as one of those kits but you'll have the full range of products that we use in our Saturday Classes, and it's extremely rare that we can't get the job done with that.
                  This would be my choice for a beginner, http://www.autodetailingsolutions.ne...imate-kit.html.
                    whats the difference between the pads i own (7k,8k,9k) and the one for the DA other than the easy centering stuff.
                    Thank you
                      The newer ones are machine washable.
                      Your you will want to wash more carefully by hand, not getting the velcro soaked.
                        Thank you
                        Do you have the W7000/8000/9000 or W7006/8006/9006? If the former then you've got the 8" pads that really should be used on a rotary as they're really too large for DA use. If you've got the latter then you have our first gen 6" pads which are fine on the DA but they are not machine washable. They should also be used with our W67DA backing plate as the W68DA plate that comes with the G110v2 is too large for them.
                          This is a really good point. U can do pretty much everything with M205,M105,some polish and Wax. This can get any car to look brand new. Also by experience having a WHOLE bunch of MF towels is never enough. Always get MF towels.
                          Good one michael.
                          Thank you
                          The Pads you own are Version 1.0 of the buffing pads. They were W7000,W8000,W9000. They work just the same as the new Soft Buff 2.0, the 2.0 are more easy to be centered. The W7000 cutting pad is no longer used because is too aggresive. The 8k with 105 works great!.
                          Best regards.
                          Dominican Republic.
                            If this forum had the LIKE button this answer would have tons of likes hahaha Im taking note for my next pourchase. Thanks alot
