door magnet and haze
  • door magnet and haze
    My neighbor has a highlander and has an advertising magnet on his driver door. He had it on for some time. When he took it off, there is a clear cloudy film within the paint. I tried using clay and scratch x to get it out. I thought I got it out but the next day it returned. Anybody have a recommendation? I used the DA polisher as well as trying by hand to get it out.
    Re: door magnet and haze
    Put some UC on a polishing pad and work it in very well as see where that gets you. You might need a second pass as well.
    2011 Jet Black 328i Touring
    2007 Jet Black 335i Sedan
      How long has it been off?
      I have seen a couple times where there was a covering, etc of some sort, and it seemed like the paint just needed to sit and 'dry out' for lack of a better word.
        If the back of the magnet isn't clean or the door isn't clean before the magnet is put on you can also get scratches. Especially if the person adjusts the magnet to get it straight. They pull up a corner and drag it into position...ouch!
        As Smack indicated, use some UC. Good luck.
        David
          I am just wondering if "UC" worked. I have the very same problem on a New 2013 Jeep. Magnet was on the door for maybe 3-4 days, and I have a white haze now. Trying to figure out the right approach.
            Are you working by hand or machine?
            Either way, UC would be a good start. You won't really know how your particular paint will resopond until you try..
              Or UP if the haze is just dirt...
                Well, I just tried using UC with a power drill and the Maguire's pads and all of that. Still have that haze. I have moved the magnets from the rest of the jeep, and only this door was affected. I am starting to wonder about the paint job itself. Since the Jeep is less than 4 months old, when I take it in for the oil change, I am gonna have them check it out. But tired using UC and had no luck....
                  Any chance of a pic?
                    I had the same problem. I washed the car first and washed the back of the magnet and had it on my Honda for about 2 weeks. I think it was the rain that got behind the magnet and stained the paint as it was wet behind the magnet all the time. Finally removed the stain with UC
