2007 honda van
  • 2007 honda van
    Hi guys. Just wondering if you could recommend a DA polishing and finishing product for a 2007 honda van. It's never been detailed at all. Mostly just automated brushless car wash.
    It's grey so it hides the swirls a bit but it's definitely there.
    I recently got the Griot's Garage DA polisher. Any help would be much appreciated.
    Re: 2007 honda van
    Just pretty standard really, always kind of start off the same way.
    1. Wash
    2. Clay
    3. Clean - I would purchase Ult. Compound and Ult. Polish, so you have a strong and a mild cleaner on your shelf. Both would be applied using a polishing pad.
    4. Wax - Your favorite wax, such as Nxt 2.0 or Ult. Wax using a finishing pad.
    5. Wax - 2 thin coats are best.
    You can do a test spot using the Ult. Polish, and see if it helps. If not, (and UP is pretty mild), you would go with the UC. Follow up with UP if wanted, or use the UP as your mild cleaner next detail.
      Re: 2007 honda van
      do you recommend the DA microfibre system on the honda finish at all?
        Re: 2007 honda van
        Ehh.. I would tend to say not if you dont need it...
          Re: 2007 honda van
          is it too aggressive for the finish?
            Re: 2007 honda van
            Well, you would tend to want the foam for general maintenance in the future, so if you can use foam from the start, it just saves buying extra stuff.
