Tire Cleaner - Powder Coat safe?
  • Tire Cleaner - Powder Coat safe?
    My wheels are Powder Coated Matte Black. I am looking for a tire cleaner that is safe to use with my wheels. Obviously, will not be using the tire cleaner directly on the wheels, but I would imagine some overspray will occur and I dont want any issues. Any ideas?
    Re: Tire Cleaner - Powder Coat safe?
    I would just use APC.
      This:
      Dilute at 10:1, spray onto the sidewall, scrub with a tire brush, flush with water.
        I just called CS @ Meguiars and was told not to use the APC...only thing safe was the Hot Rims Aluminum Wheel Cleaner and to use that on the tires.
        You think the 10:1 dilution will be safe enough for any overspray on my wheels?
          It sounds like there may have been some confusion between wheels & tires..
          10:1 will be safe. Just to be extra sure, don't let it sit there for long - i.e. rinse it off as soon as you're done scrubbing.
            He knew we were talking tires, and said that he couldn't recommend the APC for my application bc of the Powder Coat. Im sure he was just playing it on the safe side, not wanting to steer me in a direction that could cause damage, which I have no problem with at all.
            I will give the APC a shot. Thanks.
              Not sure why Customer Care would have told you that other than lumping powder coating in with bare aluminum when considering wheel cleaners. But APC at 10:1 is going to be perfectly safe on a powder coated wheel. On bare, high polished aluminum, not so much. In the case of a bare aluminum wheel, however, if you thoroughly soap up the wheel first and then spray APC onto the tire, any over spray you may get on the wheel will be immediately neutralized by the soap and you'll be OK. But on powder coated wheels, nothing to worry about here. Oh, same goes for APC+ if you decide to use that instead.
                What is the difference between APC and APC+?....just the citrus smell? Either one better for my application?
                  APC will foam more, perhaps cling more to the wheel while you work.
                  APC+ has a little touch of degreaser in it, but is low/non foaming.
                    Powder coating is pretty tough finish, pretty sure APC/APC+ wouldn't harm it at all
                    "STRIFE" aka Phil
