Bug and Tar Remover
  • Bug and Tar Remover
    Since I have to buy some new Meguiar's products I was thinking to give a try to B'nT Remover.. so I have some questions.. is it worth? I mean.. for remove bugs, hard dirt, tar or what else really difficult.. is it worth the money or even UQD and/or UW&WA can do the job (if you let the dirt soack in it)?
    Second question is.. in the description of the product it's written that best to use with Ultra Plush Super Terry.. is it the Soft Buff Terry Towel.. why better this? can't I use also a normal Supreme Shine?
    Re: Bug and Tar Remover
    Assuming you're dealing with bugs on the front of the vehicle, the best way to maximize results from Gold Class Bug & Tar Remover is to do the following:
    • Wash the front of the vehicle to remove loose contaminants
    • Liberally spray the Bug & Tar remover on the effected area
    • Cover the are with a towel that has been soaked in very warm, almost hot water
      • Allow the combination of B&T Remover and this hot, wet towel to sit on the front of the car for 10 to 15 minutes and let it break down the mess
    • Remove the towel and rewash the area, repeating the above if needed. Depending on how long those bugs have been sitting there they could be fairly difficult to remove, requiring multiple applications.
    • Don't be afraid to clay the area to remove any small remnants that might remain following the above process
      I used B&TR today, but I was quite dissapointed how hard it is to remove it. I had to washed front two times and it is still visible in small spots where I didn't get with towel. Do you have any suggestion for quick use?
