Found an old pad....
  • Found an old pad....
    So, I found an old pad behind my work bench. It looks like it was not cleaned prior to being knocked into the abyss. I am guessing it is maybe a year to two years old max.
    What are the chances of getting it cleaned and ready to use? No rocks or anything back there, just a lot of saw dust. Surprisingly enough, no wood chips on it either. It's a Lake Country CCS 4" pad.
    Thanks for the help!
    Matt
    Re: Found an old pad....
    I would get a small bucket and put hot water in it and let it soak. You could even add some dawn liquid dish soap to loosen the pre-existing material on the pad. Then rinse and air dry. Check forward spots on the pad if none your good to go.
