Purchased A G110V2 What else do I need!!
  • Purchased A G110V2 What else do I need!!
    I just purchased a G110V2 with the cruise control and 3 pads including the cutting pads, finishing pads and polishing pad. I am looking for chemicals for polishing, waxing and removing swirls and scratches. I may be doing a little side work and friends cars as well so looking to see what exactly what I need. I was thinking m105 and m205, what else should I be interested in?
    Re: Purchased A G110V2 What else do I need!!
    Or start with Ultimate compound and Ultimate polish wich is almost same as 105 and 205. When you get rid of swirls and scratches top it with Ultimate liquid wax. You need to get some good quality Microfiber towels. The other thing you can get and it works wonders is Microfiber System.
      Once I picked up a DA ....I started using SwirlX, Ult Compound, PlastX. I also love using GC liquid wax with my DA. I plan to use my sample bottle of Megs Cleaner wax this spring....once that is used up, I will likely buy either ColorX or the larger gallon size of M66(very inexpensive)
      I would get a couple diffrent size backing plates for diffrent size pads as well.
      "STRIFE" aka Phil
