Can DA microfiber system with cutting disc with correction compound take out sanding?
  • Can DA microfiber system with cutting disc with correction compound take out sanding?
    Hi Goodday,
    check with all can DA microfiber system with cutting disc with correction compound take out sanding? hope to seek advise. Thank You!
    Re: Can DA microfiber system with cutting disc with correction compound take out sand
    Whether or not our DA Microfiber System will remove sanding marks will also depend on a lot of variables. If you're going to wet sand and want to use that system to remove the sanding marks, we would recommend refining you sanding down to 3000 grit if at all possible. Even then, hardness of the paint will, as always, play a huge role here. Just keep in mind that the system is not designed to accomplish this task, so even if you're reading cases of people having success doing so, it may not work equally well for you
    That's what Mike Stoops said
    Proud to be part of Meguiars Family
      Furthermore DA Microfiber Correction System performs best on factory paints, not aftermarket paints.
      If you plan to use The System as a sanding mark removal step do a test spot(s) first to make sure there are no unpleasant surprises before buffing entire vehicle(s).
        I agree with the above. I've done it before, but it's not the most effective method at removing sanding marks.
        Rasky's Auto Detailing
