Megs. 20,21 and Klasse
  • Megs. 20,21 and Klasse
    Is Megs 20 and now the new21, about the same as Klasse AIO
    also is say for 20 is, 26, or 16 a good toper
    I have a big job lined up for Sat. a older Explorer that is in rough shape been repainted and is very oxided plan on useing ,
    83, 80, 26 or 16
    Which to drive the Miata or Mazda6
    Re: Megs. 20,21 and Klasse
    For the little I know of the products: #20, #21 are polymer type sealants. Klasse AIO is an acrylic based prep/cleaner/sealant used in conjunction with the Klasse Sealant Glaze. The AIO can be used for a base to many other products. I've used AIO twice so far as a base for #21.
    Some folks top #20 and some folks don't. Give it a try on a test area and compare the differences of #20 alone. Of course keep in mind #20 requires 12 hours to cure/bond.
    83, 80, 26 or 16
    Good luck. If the oxidation is really bad you might want to consider a paint cleaner first. Well paint cleaner after clay.
    with regards for the #83, you might could try the #80 first to see if #80 will give you the results you desire first then move up to #83 as needed.
    Good luck and don't forget to post the before and after pics.
      Take a look at this thread too. Pay close attention to the last reply. Synthetic Polymer/Sealant vs. Wax
        Ya clay is a deffinate in the process
