Did I ruin my CAR!!!!
  • Did I ruin my CAR!!!!
    Im so freaking upset with myself.
    Someone keyed my car and I tried to fix it.
    I got some 3m putty to help fill in the scratch.
    I used acetone to thin out the putty! The aceton messed up my clear coat rite? It looks cloudy and scratched?!?!?
    How do I fix this!!!! PLEASE HELP ME!!!!
    I wonder if it just needs to be buffed with a little ultimate compound and then polished?
    Always searching for the best.... Keep it country!
    SkiDoo Snowmobiles!
      Re: Did I ruin my CAR!!!!
      It's hard to tell from the pics, but your clear coat (around the scratch) doesn't look too bad to me.
      As for the scratch repair itself..
        Go over it with some UC. It looks like the acetone stained the paint. Should come out without too much problem.
        Tedrow's Detailing
        845-642-1698
          My guess is that the acetone just removed all your wax. I was thinking of removing some pin striping (paint) from my car and a body shop guy said to use acetone as it would not hurt the car paint. Said that acetone evaporates quickly before it does any damage. Tried it on an inconspicuous spot and it did not have any effect on the car's paint. I'd just use some polish, cleaner and wax.
            To answer the question you posed in the thread title "Did I ruin my CAR!!!!" - no, you didn't but someone else sure did. The only way you were going to really fix that key scratch was to go to a body shop and have the panel repainted. Doing what you did, although it certainly didn't fix the problem, it really didn't make it any worse as far as the body shop is concerned.
            Since it obviously doesn't look very pretty and you've altered the appearance somewhat, let's see about cleaning it up at least a little bit. Ultimate Compound would be our first choice to correct some of this and restore the gloss. Don't even think about wet sanding to level this down unless you're skilled in both that process and rotary buffing to remove the sanding marks. From what we know about your history here on MOL, you don't have any experience with either process. That's fine, just keep in mind that this is not really the time to take it upon yourself to experiment. Start with UC on a wax applicator pad to bring the shine back up first, then let's take it from there.
              ****, I thought he had turned the whole panel white.....
                It appears that is a solid red and not metallic color. If so you may want to try the product from Dr.Colorchip. This is a good product for the DIY type person. If that isn't you kind of project then a body shop would be my next stop.
                Live like you're not afraid to die.Don't be scared, just enjoy your ride. Chris Ledoux RIP
                PAUL SPARKS / Distinctive Auto Detailing
                317-513-4678
                  Thanks for the replies. Im gonna pick up some UC tonight. All my normal suppies/tools are located in NC. Im hoping some UC can restore the gloss of the clear coat. I dont wanna get it repainted so im gonna deal with the DEEP scratch Its a 2008 and soon to be paid off....just gonna deal with it
                  Hoping th UC will restore shine....
