washing Collinte 845 out of foam pads
  • washing Collinte 845 out of foam pads
    Tried washing my Meguiars foam applicator pad the other day.
    Just applied Collinite 845 on my windows....washed the pad in a bucket soaking in water and Micro Restore soap.
    After I rinsed out....I see a "ghosting" or where the wax was....on the yellow Megs pad....should I use a higher ratio of micro Restore in my bucket or is this Collinite wax that resistant to this soap?
    I also thought of using Megs APC+ at 4:1.....
    "STRIFE" aka Phil
    Re: washing Collinte 845 out of foam pads
    Sometimes wax and other products will stain the pads a little. I just continue using them even if they become slightly discolored. As long as there is not dirt in them then you should be good to go.
    If you really want, make that your 845 pad and use it only for 845.
    Tedrow's Detailing
    845-642-1698
