I have few light scratches on my car, caused by my careless neighbor opens his door brutally LOL. not really deep. I am looking for a customer line product and don't know UC and scratch X 2.0, which would be better?
Dummy question: UC and scratch X 2.0, which is better for removing scratches?
Re: Dummy question: UC and scratch X 2.0, which is better for removing scratches?
Depend what products you have. The proper process is to try with the least aggressive products and progress to the next more aggressive product. This would means that you will have to buy a few products. In the consumer line, UC is the strongest while SwirlX is somewhat medium. If you are doing this by hand, UC is your best bet. If you are using a DA, you may start with SwirlX. By the way, even with UC, I found it hard to remove swirls by hand, never mind scratch.
I applied UC to my car a month ago (full 5-step process), I don't think it removed too many swirls (if any) but it did give my car an excellent shine. My car is silver so these swirls are not critical to me.
The rule of thumb is if you can feel the scratch with your finger nail, the scratch is too deep to be repaired by regular detailing products.
Originally posted by mis3 View PostDepend what products you have. The proper process is to try with the least aggressive products and progress to the next more aggressive product. This would means that you will have to buy a few products. In the consumer line, UC is the strongest while SwirlX is somewhat medium. If you are doing this by hand, UC is your best bet. If you are using a DA, you may start with SwirlX. By the way, even with UC, I found it hard to remove swirls by hand, never mind scratch.
To be really candid and open about the marketing, if you will, behind SwirlX, ScratchX 2.0 and Ultimate Compound it goes something like this: All three products are derived from M105 at least to some extent but they are most definitely NOT the same product in different bottles. When the buying public has an issue they need or want to address on their vehicle, they look for a product that specifically states it is intended for their given issue. Not all consumers are as savvy as people who hang out on detailing forums, so they don't understand that oxidation, bird dropping etchings, scratches, fine swirls and other below surface defects are all basically the same and the same products and techniques will address them all. They have a scratch. They don't want a product, nor will they buy a product, that says it's for removing heavy oxidation. They want a product that specifically tells them it's for removing scratches. That's what they have, that's what they want to fix, that's the product they're going to buy. It's simply a question of education, but a bottle label is not the place to educate folks on the finer points of defect removal, the differences between above surface contaminants and below surface defects, clear coat thickness, abrasiveness variables, etc. Nobody would read such a label, let alone understand it all on first read.
So Mat's short response of "Just get the UC...." is actually pretty spot on. That's what we would suggest as a starting point for almost any defect removal process, and it's what we always start with in our training classes. How you use it can have a huge impact on how aggressive it is - type of applicator, whether hand or machine applied, how aggressively its applied regardless of method, etc. Working by hand we will always recommend using a foam wax applicator pad so that the product is doing the work rather than a terry towel that very often creates some haze on the finish.
Originally posted by mis3 View PostThe rule of thumb is if you can feel the scratch with your finger nail, the scratch is too deep to be repaired by regular detailing products.Michael Stoops
Originally posted by mis3 View PostI would think that the recent NXT would be fine to fight off the etching.Michael Stoops
Originally posted by Michael Stoops View PostIt depends on some variables. Some bird droppings are much more caustic (for lack of a better term) than others, and some will etch paint very quickly. In most cases a coat of wax or sealant can buy you some time with bird droppings and other types of attacks against the paint, but they can only do so much. Waxes and sealants aren't designed to be impermeable barriers, they are sacrificial barriers. And if you happen to get nailed by a particularly nasty bird dropping, things can go bad pretty quickly. Remember, these things can and do etch paint. To expect a microscopically thin coat of wax or sealant to truly stop this from happening would be to assume that thin coat of product is actually tougher than your paint. It isn't.
Maybe I never encountered these nasty bird droppings.
My car is usually well-waxed. I had bird droppings left on my car for a few days many times and they were washed off easily.
Originally posted by mis3 View PostMaybe I never encountered these nasty bird droppings.
My car is usually well-waxed. I had bird droppings left on my car for a few days many times and they were washed off easily.Michael Stoops
