Re: Did I mess up trying to remove some water spots?
OK, so far so good. Most of the spots are on the hood, then there are some on the sides and top of the car, but the hood is the main problem. I've gotten rid of the spots on half the hood so far, but it took almost 2 hours! I'm going to get this thing done today.
So I didn't clay first, I just washed the hood and then applied UC. Let me know if you guys think this is fine:
Saturday
1) Finish UC today.
2) Take the car to go out to dinner.
Sunday
3) Wash car.
4) Use quick detailer.
4) Clay car.
5) 2 coats of NXT wax.
So should I not clay after washing tomorrow? I thought if I flayed first then the UC would just remove the clay.
Clay is used to remove the surface contaminants and not supposed to leave anything behind. After clay, you should have a clean, smooth surface.
UC is to correct the paint, clean the surface further and leave the panels with polishing oil. Darker cars need the polishing oil to bring out the shine.
Run your hand through the car, if the panels are smooth, you can skip the clay step and proceed to the wax step. Otherwise, if time permits, clay then UC again.
Mind you that all these advices came from us, detailing enthusiasts who are very, very critical on the appearance of our cars. The purpose of your current exercise is to remove the water spots, UC did the job so maybe you can just apply NXT and call it a day !!!
emoves paint overspray, fallout, environmental contaminants and more
Usually the water spots are only on the flat surfaces anyway. You could just clay the hood one more time because if you can "feel" that the surface is rough, you might really feel a real difference. Then, Ultimate Compound will bring those water spots under control much easier than without the clay process. If you notice any haze or anything from the UC, you can follow up with something milder like ColorX before you wax.
Yeah, but I already used UC. I got all the spots off.
Just so you know, I had other things to do today and I knew I wouldn't have time for a wash/clay/UC/wax. For me, I just wanted to make sure I could wash/UC to get those spots out. I was worried the spots would be stuck and to tell your the truth, after a first application of UC, I still saw spot remnants. I really had to work at it, but 5 hours later, no spots.
Tomorrow or Monday I'll have more time. So do you think it would be fine to wash/clay/quick coat of UC/wax? Or should I do something else?
I'd suggest doing a test spot first before jumping to UC. In good light, try the Cleaner/Wax. Try using a foam pad and if that doesn't remove the spots step up to a terry or MF covered pad. If the spots are removed you know that the process will work over the whole car. If not, step up to ScratchX, again, are the spots removed? If not, then I'd step up to UC and try again. Bear in mind that using more aggressive polishes may induce swirls depending on the softness of the paint and the application method/technique. Good lighting is imperative to examine the test spot for this.
All the spots are gone. I just want to know if I should only wash the car and wax now or do a wash/clay/UC/wax. The other ppl said that should have clayed first before UC but I didn't
If you feel up to it and have the time, by all meansdo the complete 5-step routine. Otherwise, just wash/wax for now and do the complete process in 1-2 months.
I work slow. the complete routine takes 6-7 hours while the simple wash/wax takes 2 hours.
From where you stand now, either way is perfectly fine.
If I were you, after the 5+ hours of UC yesterday (more importantly, all the water spots were gone), I would just wash/wax and relax for the weekend.
