need your help
  • need your help
    i have a 2011 hyundai sonata with a black metallic finish and when using both ultimate liquid wax(every few months with the 3-5min rule) and ultimate quick wax(after every wash) while applying in the shade i always get these dark patches and i have a very hard time removing them and im starting to thinking its the type of finsh i have and not liking this wax where as carnauba wax has no issuedoes any one have any suggestions or should i just go back to carnauba
    thx.
    Re: need your help
    It is possible the wax (or your technique) just doesnt mesh well with the car.
    Sounds like you may be using too much product, the new ones require a very thin coat.
    Also, you have done claying, cleaning steps before?
      Re: need your help
      i put it on as thin as possible and claying makes no difference and that would not explain why it also happens on the ultimate quick wax spray
        Re: need your help
        Have you washed your car after claying? Just a thought.
          Re: need your help
          Its not so much 'making a difference', but having the best surface possible makes applying thigns easier.
          I have used the UQW more than I have the UW, and i only get streaking with the UQW when it is applied to heavy in a spot. It is a pain to remove if thick.
            Re: need your help
            thx.
            I had that same problem with NXT. In my case I found that using fresh clean applicators and cloths that have no residue from other brands of wax or polish really helps. I now thoroughly clean my applicators and cloths after every use.
              Re: need your help
              I have a 2012 Elantra in "Harbor Grey Metallic," and I've experienced the same issues with Ultimate Wax, but not with UQW. As I noted in the big UW thread, the application method recommended by Mike (very thin coats, work panel by panel, wipe off after 3-5 minutes) does yield better results than the traditional method applying sealant, but I still experienced some streaking. It's possible that I'm still using too much product - sounds like you may be, as well.
              For the UQW, it helps to use a second MF for your final wipe - if you only use one towel, it tends to get saturated with product to the point that it can't remove any more residue.
              Makes me wonder if there is some incompatibility between Hyundai paint and UW, though... I wish we had a formal database of vehicles and products that work well.
