i'm a little new to detailing but...
  • i'm a little new to detailing but...
    polishing pads is to put on polish?? and finishing pads is to take off polish??
    Actually, the polishing pads are used to apply compounds and polishes. The finishing pad is used to apply glazes, sealants, and waxes. Products should be removed with a microfiber towel like the Supreme Shine or the Ultimate Wipe.
      so the rotory just puts it on ?? you don't use it to take off ??
        yeah, you would remove the polish residue by hand with a microfiber towel or soft terry cloth. Meg's makes ultimate bonnets, but I don't know if I would want to use them with a rotary.
          PAD INFORMATION
          Actually there are two kind of pads used for paint finishing:
          a. Cutting pads for correcting paint finish problems
          b. Polishing or Finishing pads to remove swirls and polish
          In paint finishing if you have a problem you would use a three step process:
          Correct
          Swirl Remove/Polish
          Correct
          CORRECT
          Use a high speed buffer; cutting pad (either wool; poly/wool or foam) and one of 4 compounds (heavy; medium; light or micro-fine grit). Normally today's clear-coat finishes do not need a heavy or medium compound nor a wool cutting pad.
          SWIRL REMOVE/POLISH
          Use a high speed buffer; foam polishing/finishing pad and a swirl remover (not a filler) polish. (I believe these are one and same, you can swirl remove and polish with one product).
          CORRECT
          Apply wax or better yet, a paint sealant by hand or by orbital for final protection.
          This is the basic and most correct way to deal with paint finishes that have problems.
          If you are dealing with a good paint finish you can simply PROTECT IT by applying wax or sealant.
          Or, you could use an orbital with a swirl filler to fill in the micro fine scratches and then apply a wax which will fill better because it has more solids.
          Hope that helps.
          Bud Abraham
          DETAIL PLUS SYSTEMS
            I would suggest getting a PC and skipping on the rotary for a while...
