Microfiber Correction Pad Failure?
  • Microfiber Correction Pad Failure?
    Hey guys,
    I bought the amazing d/a microfiber correction kit and have used it on a couple cars so far. It produces great results, but either I'm doing something very wrong, or I have a faulty cutting pad.
    After only a couple of cars, one of the pads did this:
    I have been using the red pads on my G100V2 with a speed setting of 4 to apply the pink compound in Step 1 of the process. I always make sure they are centered nicely, and I only do 24x24" sections at a time. I always stop to use air and re-fluff the fibers and add a little bit more compound. I never pull the pad off by the fibers or the foam in between. I always lift up on the backing itself and peel from there.
    It seems very strange that it would fail this soon. What could I have done?
    Re: Microfiber Correction Pad Failure?
    Interesting where it split.
      Call Meguiars Customer Service. I think they can/will help you out. Great bunch of guys there. I had pad failures and Nick took great care of me.
      (800) 854-8073 *3838
      Don
        Thanks for the info. I will do this.
