A friend's, badly "dust-storm blasted" headlight covers are no longer white, but still have deep scratches and erosion of variable depths in the plastic. At least the headlights "light" the road ahead, but still ugly.
To achieve the above, I used Megs consumer version of the Headlight Restoration Kit (with the drill attachment). It won't take me any further.
Based on what I have read, I was planning on doing the following, knowing I cannot take it as far as you guys, but it may be "good enough" for my friend.
I already this:
Meguiar's Professional 3" Hand Pad
(....and if possible, would like to work with it to save $.)
Here is what I plan to get to go with it:
I am not sure if I even need the foam interface.
I don't know what the difference is between these pads and Sanding disks of the same name. One appears to have the foam backing the others not.
I am also unsure of what I am doing, and for that reason only want to increase aggressiveness a little at a time.
Thanks for all I have learned here.
Jeff
I already this:
![]() | Meguiar's 3" Micro Hook/Loop Foam Interface Pad![]() |
Meguiar's 3" Unigrit 1000 Foam Finishing Disc |
Meguiar's 3" Unigrit 3000 Foam Finishing Disc |
Jeff
