clay lube alternative ?
  • clay lube alternative ?
    i ran out of quick detailer is there anything else i can use would uqd work as lube im thinking of buying that but is there any home made fourmula that works water and ?? something like that
    Re: clay lube alternative ?
    Well, can you clay with UQD.. yes, but it is expensive and wont work as well.
    Soapy water would be the next best option if no QD/LT/FI, but soap can break down the clay if you store it for a while between uses.
      Personally, I use Optimum No-Rinse as a clay lube, as it's much more economical than any QD product. In a pinch, just fill a spray bottle with water and add a few drops of dish soap to break the surface tension, or even APC or Simple Green diluted about 1:50. On a really contaminated car, such as one that's been parked under a tree for months, I'll use one of these mixes to flood the contaminants away and prolong the life of the clay.
      Bill
        Meguiar's Hyper Wash could be a very cost effective alternative.....
