Getting reaquainted with #7
  • Getting reaquainted with #7
    After my encounter with bambi, the new hood and front end of my car made the rest of the car look terrible (SS red paint after a hard winter). All I had was some Deep Crystal Polish (DC-2) and I gave that a good rub with the PC and a polishing pad. It applied and came off beautifully and combined with two coats of NXT2, the car was sparkling again.
    Well I finally bought some #7 so I could start my summer side work detailiing cars for a few extra dollars. First up was a BMW 528? with a carbon fiber hood. It was a hot day and the 7 spread beautifully. My method for removing the #7 is to apply the first of two sealant coats directly over the #7, it typically makes the removal of the #7 much easier. A good rub of #7 with a coat of NXT2 overtop, remove, then put a fresh coat of NXT2 on the car then wait for the swipe test and remove. This usually results in a near-perfect finish. I did my father in law's truck today (60* and humid). First the car wouldn't dry after the wash...too cold & damp I guess then the #7 didn't want to spread as well as it did when it was warmer. I had started with Megs UC, so I had a good surface to work with, it just didn't want to spread as thin. Since I was working on a truck I used Collinite 845 Insulator wax. The wax spread over the #7 fine and removal of the wax/#7 was just as easy as before. The second layer of 845 went on with no issues.
    So after seeing how well these cars turned out using #7, I decided mine needed repolished and waxed. Since I had just used UC only a week or so before, I went straight to the polishing step. As with the truck, the #7 didn't want to spread so well in the colder weather. On my car I used the NXT2 and the first coat that went on directly over the #7 was a BEAST to remove. I know that even if you apply NXT2 too heavy it's still easy to remove so it had to be the #7 and the cold weather causing me issues. The second layer of NXT2 was more like normal, easy to remove with only slight streaking on a few of the panels...I did have a bit of a "waxident" I accidentally applied the NXT2 to the hood which was only painted a few weeks ago.
    To make a long story short (too late) once I got eveything buffed off and used the UQW on the edges etc. I was able to stand back and see the car in the setting sunlight...WOW, and I thought the DC-2 made the red pop, the car is now red-hot-chili-pepper-fire engine-Rudolph's-nose-has-nothing-on-my-car-red.
    Although the #7 is a bit more work in cooler weather, the results are most definately worth it.
    Don
    12/27/2015
    "Darth Camaro"
    2013 Camaro ... triple black
    323 hp V6, 6 speed manual
    Re: Getting reaquainted with #7
    As a former #7 user, I have to tell you that the new Ultimate Polish seems like my new glaze substitute. UP combines the best properties of #205 AND #7 into one product, and is so much easier to work with (especially to remove) than #7. It gives the same deep, wet look to the paint as #7. Really like the UP.
    Jim
      Jim
      I almost grabbed the UP instead of the #7, but since I had a car to do that day, I opted for the more familiar #7. Since then I have gone over many of the reviews and found that almost eveyone's opinion is that UP > #7.
      BTW, the wife cleaned out the garage to get the mower out and HAD A COW over the "hundreds of bottles of car stuff." And is giving me grief about buying anything else. Since a bottle of #7 lasts so long, it looks like it will be a while before I can try the UP
      Don
      12/27/2015
      "Darth Camaro"
        I went back to #7 after a long time, and found a few tricks. First it needs to be a very light coat I could do the entire truck. Then wipe it down lightly leaving some on the paint you don't want to take it all off at one time like you do with wax. Second time around wipe a little more, on the 3rd its wipes of easy with no residue. Then I top coat with M26 Hi-tech yellow wax let it sit for a bit then remove. Then pull your vehicle out into the sun and look out! Its like it was just painted. Both my Avalanche and the Denali are black and they have never had that much shine before. I had that bottle of #7 sitting around for years, now its the only way to go for me.
          I do love good o'le #7. Some of my most favorite jobs came from using it.
            Originally posted by Don View Post
            ...BTW, the wife cleaned out the garage to get the mower out and HAD A COW over the "hundreds of bottles of car stuff." And is giving me grief about buying anything else...
            Your wife must know mine because they're both singing the same song.
