Can i do this by hand
  • Can i do this by hand
    This coming spring break i plan on detailing by hand. Can all of these easily be used by hand??? In the process i wanna get rid of some swirl marks.
    1 Wash
    2 Clay
    3 #9 Swirl remover
    4 #7 Glaze
    5 NXT Wax
    is this a good process???
    I have some pretty big swirls and wanna no how I can get them out by hand. Maybe DC 1and2 or Swirl Remover or HandPolish???
    If your going by hand and can't get hold of a pC I would personally Apply scartch - x all over or at least to the affected parts. This has more 'cut' than the products you listed. I have no experience of #7 but hear its tricky but not impossible t get right. You may be better off with something like #81 hand polish followed by NXT
    If you can guess how many coins are in my pocket I will give you both ;-)
      I agree that for hand application you'd probably be happier with ScratchX instead of the #9 when going after swirls.
      PC.
        Hey,
        Like the others have said, using ScratchX to remove your swirls by hand would be the better choice.
        Here is a link you may find helpful:
        How to use ScratchX by hand to remove swirls, scratches and water spot etchings (http://meguiarsonline.com/forums/showthread.php?t=1516) How to use ScratchX by hand to remove defects like these, Scratches Swirls Bird Dropping Etchings Water spots Scuff and Mars + + = Success! A couple of important notes to
        Cheers!
        Tim Lingor's Product Reviews
          M-09 by hand does not give very good results. You would be better off going with the M-80 from what I have heard on here.
          Kevin
