Light Holograms in Dodge Ram black metallic
  • Light Holograms in Dodge Ram black metallic
    hows it going guys, wanted to see if you could help me out a bit. i have a dodge ram with the black metallic paint. i've got it in overall good condition, but have some holograms that are bugging me. they're light and only seen at certain angles, but still there. i've worked with 205 and a white lc pad on my pc and they still seem to be there.
    any insight on what i should do.. another pass with the same setup? get a little more aggressive?
    thanks ahead of time for the help
    Re: Light Holograms in Dodge Ram black metallic
    Yep!
    worked for me on back caddy.
    I used Ultimate compound followed up with Ultimate Polish and sealed it with wax.
    When you use polish it will take a while to get results. Take your time and go over areas few times. are you using correct pad?
      Try working the product in a little more aggressive. Possibly a little more pressure on your PC or kicking the pad strength up. We don't want you to be to aggressive, because as you state they are light scratches in the paint.
      Andrew Scruton-Wilson
      Latin America Training Specialist
      Irvine, California
      alwilson@meguiars.com
        Ya, they are only visible at certain angles, but still there, thats why i started with 205, for the light abrasive action. ill take another run at it with the same white pad/205 setup, and work it a bit more, but if that doesn't do it, should i bump to the orange lc pad/205 or try UC/white pad?
