Hole Repair..
  • Hole Repair..
    I hope this is the right place to post this..Has anybody on here ever used A Bondo Hole Repair Kit..And how did it work..I have a rust hole thats through the metal..About 2 inches long..
    Re: Hole Repair..
    The Bondo repair kit will work fine. Just follow the instructions, sand as required and paint it. You may need several coats to get it just right. The problem is that if you have a 2 inch hole, that rust is covering several more inches, you can't see. To repair it you need to get all the rusted area cut out and it should be replaced with fresh metal, welded in and then bondoed over to finish it off.
