How do I prep paint before using #80?
  • How do I prep paint before using #80?
    Beside washing and drying, what do I need to do? My finish is new, I have clayed it and put 2 coats of NXT. Do I need to remove the NXT?
    Re: How do I prep paint before using #80?
    You're set to go... the M80 will remove the NXT.
    Are you applying with a dual action polisher?
      Yes, I am applying with a DA polisher.
        Take your time, move the polisher slowly over the finish and let the product do the work. Apply 3-5 lbs of pressure, but not so much the polishing pad stops rotating. Work a small section at a time, overlap your passes and overlap from one section into the previous section.
        You will remove your swirls and any previous coats of wax.
          Thanks.
