How To: Use Meguiar's Super Degreaser to clean polishing pads
  • How To: Use Meguiar's Super Degreaser to clean polishing pads
    The Easy and Affordable Way to Clean Your Polishing Pads
    Keeping your polishing pads clean is extremely important to the performance and life of your polishing pads. I have used all of the machines, gadgets, and tools to clean pads, and while some of them really do a great job, they are not always practicable. I have always used dedicated pad cleaners, but a friend suggested to me that they where just degreasers. I looked around the garage, saw a spray bottle of Meguiar's Super Degreaser, and gave it a go. The results were instananeous. Over time this became my preferred method of pad cleaning and I enthusiasticly recommended this process to everybody who would listen.
    Degreaser vs. Soap
    A lot of detailers use liquid soaps, most commonly dish washing soaps, to clean their pads. Most of the stronger soaps do a great job, but can be frustrating to fully rinse out of the pad. It seems several hours of rinsing later you can still squeeze foam soap bubbles out. Meguiar's Super Degreaser rinses clean very quickly, as it is designed to release from surface quickly. Most dish soaps will leave behind a film to promote water sheeting off over plates and silverware, to resist water spotting. This film can be very difficult to fully remove, particularly once trapped inside the foam cells of a pad.
    Two Bucket Method
    While it is not necessary to have two buckets for pad washing, it certaintely helps. The wash bucket it were all the dirty cleaning happens, and this water will be contaminated with solution and polish residue. The rinse bucket is used after the pad has been cleaned to flush out any remaining solution from the first bucket and to ensure the pad is perfectly clean.
    Getting Started
    • Two Buckets- The larger the better. Fill each bucket up with water.
    • Meguiars Super Degreaser- Diluted 10 parts water with 1 part solution.
    • A pad brush- Used to scrub stubborn stains from the surface of pad.
    • Dirty pads
    The surface of this Meguiar's Softbuff 2.0 Cutting pad has a lot of embedded abrasives and is in desperate need of cleaning.
    Spray the surface of the pad liberally with degreaser solution and massage the cleaner into the pad.
    Dunk into the wash bucket. Massage and scrunch the pad in the water. Polish residue will release immediately.
    Finally wring and inspect. There is some stubborn residue on the bottom right corner of this pad.
    If needed, spray more degreaser on the pad and brush any stubborn areas with a stiff nylon brush, such as a pad brush.
    Dunk and flush out as much solution in the wash bucket. Finally wring out as much solution over the wash bucket.
    At this point the pad should appear clean, and well rang out. Finally massage and wring out any solution in the second bucket; the rinse bucket. This will ensure that all of the contaminated water from the wash bucket is removed and the pad is completely clean.
    Finally spin the pad dry on a machine, if available, and allow to air dry completely before use.
    The end result is a pad that is completely clean and should be free of any residues which could hamper further use. This method will clean the entire pad, instead of just the surface.
    A Method for All Pads
    This method, because of the submergence of the pad, is suited to all pad types including wool and multi-fingered pads that have large surface areas. These pads tend to require scrubbing for the best results.
    Notes
    • If you have sensitive skin or notice any irritation you should consider wearing nitrile, vinyl or latex gloves.
    • Reticulated or 'closed-cell' foam pads will require additional time to dry. You can identify these pads because they will release little air bubbles that will make the water appear cloudy when massaged underwater.
    • You should change the water in the buckets when they become contaminated. Try to keep the rinse bucket's water as clean as possible.
    • The large surface area of wool, micro-finger, and microfiber pads will contaminate the water much quicker than foam pads. Clean the water more frequently
    Re: How To: Use Meguiar's Super Degreaser to clean polishing pads
    Awesome Todd! Thanks for the write up. I've already bookmarked this thread. I use APC for cleaning my pads, but I hadn't considered Super Degreaser. I'll have to give it a try!
      awesome just like John mentioned ive always used APC. I just got a new bottle of Super Degreaser will have to try this out on some dirty pads. Thanks for assuring me its safe haha
      - Markito -
        great info and write up!
        Thanks for sharing!
        1976 Cutlass S
        2001 PT Cruiser
        1990 454SS
        1989
        Suburban
          Very good info and tips, Todd.
            Nice post, Todd!
            Definitely worth some rep.
            Bill
              Thanks for the compliments and I'm glad to help!
                Thanks Todd! Really helpful.
                I also like to spray the pads with some APC and then throw them in the wash.
                Tedrow's Detailing
                845-642-1698
                  i like this
                    Great write up Todd. The Super Degreaser does work great and if it can be done soon after the polishing session it'll be even easier to clean. I'm guilty of not cleaning pads for a few days.
                    Also, if you're going to use your DA to spin dry your pads make sure you have the palm of your hand lightly over the spinning pad to keep it from flying into your neighbors yard and their dogs tearing it apart A rotory is great for the spin dry cycle.
                    Jesse
                    www.ShineTechAutoDetail.com
                    Facebook www.detailing.com
                      Thanks everybody for the compliments. Loving the 'reputation' love as well
                        I agree. Super Degreaser is the best pad cleaner. Makes it too easy.
                        Colin
                          Bumping this thread as pad cleaning has been a popular topic. I have been using APC, but I think I'm going to pick up some Super Degreaser to try this with.
                            Great tip, thanks Todd. I've been using a dedicated pad cleaning product but that can get expensive after a while..
                              a gallon of SD is pretty cheap too....currently only $15.49 at ADS...........Hmmm add that to my shopping list
                              "STRIFE" aka Phil
