Wool pad
  • Wool pad
    Can anyone advise what is the purpose of using wool pad ?
    Re: Wool pad
    Its just a more aggressive pad.
    It would be used with a rotary for severe defects.
      Re: Wool pad
      Much faster cut with rotary buffers.
      If you need fast paint removal, for example after sanding, that's a really good pad to go with.
      Wool pads tend to leave their own stuff behind, mostly swirls.
        Re: Wool pad
        Wool vs. Foam
        Pro -faster cutting generates less friction induced heat and therefore leaves the surface cooler, removes heavy oxidation much more efficiently than a form pad. Use foam pad for slower and finer cutting. Wool pads are easier to control compared to foam. They glide as the wool nap ‘lies down’ and will conform to vehicle body shape easily. Make certain to spur the wool fibres when it loads up with product.
        Con -wool can leave micro marring (buffer trails) finish with a foam pad to remove. Don’t overwork the polish as wool will break diminishing abrasives faster than foam, the surface lubricants will dry up faster and you could end up dry buffing unless you’re careful.
        There are too many variables with different wool and foam types, along with too many compounds to give a definite choice.
