How do you remove Backing plate for G110V2?
  • How do you remove Backing plate for G110V2?
    I just bought the new meguiars microfiber correction system with the new backing plate(67---). How do I remove the old? New at this!
    Re: How do you remove Backing plate for G110V2?
    You should have a little wrench that came with the polisher. Insert it behind the pad to hold the shaft. Should be some flat spots for the wrench to fit on. Twist the pad counterclockwise with your hand. It should come right off.
      Did it. Thanks!
