Dried concrete
  • Dried concrete
    Hey everyone, I went to see my mom & dad the other day and she told me to come check out her car. I found spots of rock hard dried concrete on the body of the car in different spots. PLEASE HELP ME by giving me some suggestions on how to remove this concrete from the car! (if possible) Thanks for ALL your help.
    Re: Dried concrete
    I want to say I have heard letting vinegar soak on the concrete will soften it up. Just be VERY careful about not dragging it along the paint when wiping it off.
      Re: Dried concrete
      Concrete? Like it splattered from something nearby? Wow! Like Mark said, being careful is definitely the key here. Clay bar? Gently!
        Re: Dried concrete
        I would say best thing is to post pics so we can see whats going on.
        -Sohc-
          Re: Dried concrete
          Ok, don't laugh. Sugar will break down the concrete. If you can soak it in a solution of sugar water it will break it down. I am thinking Coke might work. A heavy syrup solution would also work. Your going to have to get creative to build a little well to hold the liquid.
          Try it on a test spot!!!
            Re: Dried concrete
            Scrape it off w/ a single edge razor. Sometimes you have to break an egg to mke an omellette.
              Re: Dried concrete
              Give it a good blast with a pressure washer first.
                Re: Dried concrete
                Thanks for the tips & I will be VERY CAREFULL which ever one I deceide to try. Will let you know the outcome!
                  Re: Dried concrete
                  Here is another suggestion...................
                    Re: Dried concrete
                    Hi 30th97z
                    Looks like the great minds of AllenB #5 above and Kornercarver #9 above are on the right track.
                    Go with the sugar first and if all fails then spend a few bucks.
                    Sure would be a lot better than a repaint.
                    Keep us posted as there are lots of us that would like to have the answer to removing concrete.
                    Best of luck.
                    Have a great weekend.
                    Harry
                    2004 Toyota Tundra Limited V8 Dark Met. Green
                      Re: Dried concrete
                      I found this as well:
                      Concrete Spots:
                      Calcified water spots on paint and glass, water and concrete spots are pretty much the same chemically - calcium carbonate, with the concrete being cross-linked with water
                      Methodology
                      •Apply 1:1 ratio water with distilled White Vinegar solution, and using a spray bottle, spray that mixture on the spots and let them "soak." Then rinse with water and repeat as necessary.
                      •If the ambient temperature water/vinegar mix does not work, warm (100-120 degrees) 100% distilled White Vinegar, saturate a clean kitchen sponge with pure vinegar and hold the sponge over the concrete spots for a few minutes.
                      •If the above do not remove them try equal parts distilled water, isopropyl alcohol and distilled white vinegar. The acid in the vinegar will help etch and dissolve the concrete.
                      •Rinse the area thoroughly with water after the vinegar and then reapply wax or sealant to that area.
                        Re: Dried concrete
                        http://www.topoftheline.com/cement-c...over-auto.html
                        That's the most effective and safe removal product for dried concrete
                          Re: Dried concrete
                          Concrete Spots:
                          Methodology
                          Good advise
                            Re: Dried concrete
                            WOW, you guy's & gal's are CRAZY HELPFUL on this site! I have not started on the car yet because of this crapy cold & snow up here in south eastern Michigan. I will try things one by one like I stated before and let everyone know the outcome! THANKS AGAIN FOR ALL THE HELP!!!!
