Advice Needed...
  • Advice Needed...
    I just got a PC and some #80. Should I go with clay, #80, and 2 coats of nxt, or should I also use my DC paint cleaner before #80?
    Hi turbodreamer...
    Either way is acceptable.
    My suggestion is to try both methods to see which may work best for you and your individual paint finish. To do this, I would put a strip of masking tape down the center of your hood. Do half of the hood with the DC/#80 combo and do the other half with #80 alone.
    Once I had applied to both sides, I'd pull it out into the sun to assess the finish. Based on those observations, I may or may not continue with the DC.
    I hope that helps out a bit! Please let us know if you should have any other questions!
    -RP-
    -The Final Detail-
    Lagrange, Kentucky
    thefinaldetail@insightbb.com
      I would agree with RP........... give both a try. Using the #80 prior to NXT might give a tad different final appearance. Also, keep in mind, that #80 will remove some fine swirls that DC1 won't touch. So, if you have swirls, then theres not much of a choice......... go with #80.
      Boss_429
