Has anyone ever done this? I have several small chips on the lower pannels that i have touched up and are not noticeable but to me. It leaves that "touched up" look in the paint. I guess the question is, can you wet sand that to smooth the touched up areas to make it look normal? If so, what steps do you use?
Wet sanding after using touch up paint?
Re: Wet sanding after using touch up paint?
Originally posted by redman722 View PostHas anyone ever done this? I have several small chips on the lower pannels that i have touched up and are not noticeable but to me. It leaves that "touched up" look in the paint. I guess the question is, can you wet sand that to smooth the touched up areas to make it look normal? If so, what steps do you use?
Rappy.
Mark Kleis did a little write up on chip repair a while back.
Wet Sand Black Chip RepairBrian
