i have a 91 cadillac brougham d elegance with a full white vinyl top, i tried everything under the sun to get it clean. nothing worked until i tried the MR CLEAN MAJIC ERASER. box of 4 at wal mart 5 bucks. there is not another product out there that will work any better. it took me 1 hour to clean it. it looks like it just rolled off the showroom floor. it gets all of the dirt out of all the cracks in the grain 100 percent. then put on 2 coats of nu vinyl protectant. you can find this at true value hardware stores. it has uv protection, dries hard , and wont run off and streak your glass when it rains.
cleaning a vinyl top
Re: cleaning a vinyl top
Vinyl tops
Vinyl fabric or polyvinyl chloride (PVC) is covered by a thin layer of plastic. To keep vinyl fabric soft and flexible, manufacturers add agents known as plasticizers to the raw PVC. A major function of the topcoat is to hold in these plasticizers, which otherwise would quickly evaporate. If the topcoat is damaged or degraded, plasticizers begin to escape leading to embrittlement/cracking/ and ultimate failure.
It is normal for the plasticizers to gradually dry out over time. With proper care, however, this process can be slowed significantly. Always use products that will allow surfaces to dissipate heat normally. Like all detailing task’s the correct preparation before applying the product will ensure that it works correctly, and has both durability and aesthetics.
Iz einszett 'Plastik-Reiniger' is an intensive, non-corrosive, non-acidic two-phase deep cleaner for vinyl and urethane, that removes grime build-up thoroughly and effortlessly, these chemicals restore your vinyl’s original texture and resiliency; use to clean all coloured and clear water-based acrylic polyurethane covered automotive upholstery; this product is biodegradable, formalin-free and environmentally friendly.
Wash vinyl surfaces with soapy water and a soft bristle brush (Sonic Scrubber) rinse with clean water and then thoroughly dry. Then use 1z Plastik Reiniger before the application of a suitable protection.
Protection - with 1z einszett Vinyl Rubber Care & Potectant "Tiefenpfleger” provides a temperature-resistant seal and a low-shine matte finish Dust-resistant and retards the fading effects of UV rays to keep exterior ‘rubber’ and vinyl looking like new. UVR protection is a sacrificial / renewable component; this is due to the UV protection layer being degraded by exposure to the elements (sun, sand, road or sea salt, and etc) so it is imperative that you renew it and needs to be re-applied on a regular basis (dependent upon location climatic condition)
Application - Spray onto a clean micro fibre towel, agitate it well and then allow it to dwell for 10-15 minutes. Finally using a clean micro fibre towel buff it to ensure it permeates~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ Blog – http://togwt1980.blogspot.com
