How to apply Cleaner Wax?
  • How to apply Cleaner Wax?
    I have an unopened bottle of Cleaner Wax, the one that comes with the Smooth Surface Clay Kit.
    How do I apply it? I will be working by hand and my car hasn't been polished before (by me at least). I suppose the Cleaner Wax will brighten up the paint a little? The paint is in good condition so I'm in no rush to run out and get some polish. I currently use Nxt Gen Wash and Nxt Tech 2.0 Wax. Used the clay kit once before as well. I will clay again before I use Cleaner Wax.
    I suppose I will apply it like a normal wax but work it in for a little while. Do I use a foam wax applicator pad or a microfibre towel? For how long should I work it in?
    Re: How to apply Cleaner Wax?
    yeah u can use it with the foam pad.
    just work it in a lil bit n wipe off
    Don't get so caught up making a living that you forget to make a life.
      You still use thin coats like you would with NXT 2.0. The difference is that you work it in a little more than the NXT 2.0.
      2-3 passes over a section is sufficient to properly work the cleaner/wax.
      Using a foam applicator is best IME.
      Tedrow's Detailing
      845-642-1698
        You want to keep it somewhat thin, but you may need a little more than you would with the Nxt 2.0 so you have enough to work in a little.
