Messed up the Wax Job in Nov...
  • Messed up the Wax Job in Nov...
    Back in Nov when my 2011 Camaro showed up, I put a quick coat of Nxt on the car so there was 'something' there for the winter months. It was cold, late in the day and I put it on too thick. Ended up not getting it all off and have white marks here and there.
    Sometime soon, I'm hoping to get a nice semi-warm weekend to fix this.
    Do you think a Clay Bar pass and a run over with the Meguires Paint Cleaner (Step 1 on the 3 part series) will clear it up?
    Thanks!
    Re: Messed up the Wax Job in Nov...
    The problem should be eliminated after properly washing the car.
    What color is it?
      Dark Metallic Blue. The wax that's left behind isn't coming off on a wash. If I buff it, it's comes off. It got dark, couldn't see what I was doing and I didn't get all the wax off. It's not just residue...
        Yes.
        --Al Kimel
          Help need replacement variable switch for g220
          Hi not sure if this is the right place to post this, however need help i have a g220 polisher i bought a while back well it was a christmas prezzy from my other half,well thought i'd give it a try but i turned it on and well all was well then it stopped on further investigating discovered fuse gone, replaced the 10amp fuse now have another problem with it if i turn it to speed six it switches on but flatout speed!!.anything else i.e 1 to 5 nothing dead , i took cover off and tested switch and turns out switch is at fault there is a small white curcuit board seems to be in two halves, broken. !!!Where can i obtain a new replacement switch??.really looking forward to using this still as new never had a chance to try it yet !!.
          hope someone can help thanks Steve.
